So I bought a Gateway Desktop PC DX Series DX4720-03 years ago. I am currently in college and just need a computer that can run Autocad and Solid Works. Anyways, my old pc has not worked in years so I opened it up last night and found that the power supply is not working (shorted the green wire with ground and nada).
It has a Lite-On Ps-6301-08A in it currently. I need either a replacement Lite-On or a bigger PSU that will fit the case. The fan points backwards, next to the plug-in.
I may get a little bit more wattage because I may upgrade the graphics card if it cannot run that modeling software.
Thanks for the help!
EDIT: Here's a great link so you can look at the case and get a better idea of the requirements. http://www.newegg.com/Product/Product.aspx?Item=N82E16883113078 click the 3 dots next the the pictures to get more pics of the case
https://linustechtips.com/topic/658772-replacing-an-old-power-supply/
Looks like standard atx form factor to me. Just throw a 80+ psu in there.
Budget Rig "Curable":     | FX 6300 @4.5Ghz | Asus R9 270x | Asus Crosshair IV Extreme | 16GB HyperX Beast | 120GB PNY SSD
Tablet "Buddy":                 Trekstor Wintron 10.1|
The EVGA 450B/500B would do perfect for you. You're the target audience for that PSU :P
Does it matter that the fan is on the top of the unit and not the rear? Because mine is facing the rear and the EVGA is on top. =/
So you have a case with a top-mounted PSU? I'd assume that the fan can only face into the interior of the system then, but it won't be right under a GPU so it's not the end of the world.
I'm not sure about the terminology but I wouldn't think the PSU is top mounted. Here's what the back of it looks like. 83-113-078-10.jpg
the GPU is in the bottom left hand corner of the case on the second image.
That case has a top-mounted PSU. The PSU is on the top part of the case.
6 minutes ago, aholwi00 said:
I gotcha! So you still think that PSU that you recommended should work?
The EVGA 450/500/600B will all work perfect for ya.
