Help with Dimensions
Go to solution Solved by Lubi97,
21 hours ago, dada1134 said:
Yes it supports SLI
That is not the problem.
The "problem" is, that the Zotac GTX 1080 AMP Extreme has a size of 3 slots.
What you have to check is, which PCIe slots are being used on the motherboard while in a 2-way SLI config. But from the looks of it, it should fit.
Yes it supports SLI
https://linustechtips.com/topic/658332-help-with-dimensions/#findComment-8534208
