First time PC Build Advice
37 minutes ago, Tim Serious said:well in that case keep your gpu it still will be respectable in most games ..... sell it after a year or so ..... put an ad on olx or quickr maybe someone will buy it in future ......
for 50k ( excluding graphics card) i don't think u can get i7 6700k as 6700k is alone 25k so get this instead ....
1) i5 6600 16k- 17k
2) b150 motherboard 7-8k
3) 16 gb ddr4 ram 2133 mhz (2x8gb) 6k
4) ssd - get the zotac 240 gb whichever good u can find under 4.5k
5) hard disk western digital 1 tb 3.5 k
6) power supply 5.5k
http://mdcomputers.in/smps-1608243022/80-bronze/seasonic-smps-s12ii-520w.html?sort=p.price&order=ASC
7) any case for rest of your money .....
Well I am getting the parts directly from a distributor in Lamington Road
1) i7 6700k costing me 24k
2) Asus Z170 Pro Gaming Mobo 13k
3) 2 X 8 GB HyperX Fury 2133 Mhz Ram 4.5k
4) Samsung Evo 850 250gb 5.8k
5) WD Hard drivie 2 TB 5k
This is max cost for this build 51k. Everyone is suggesting a new PSU so i will get a new one is there any 4gb GPU under 15k i might higher my budget m already using an i5 2500k need to get an i7 for sure this upgrade.
i did google for GPU but bit confused would you recommend AMD over Nvidia, if yes/no which one under 15k budget
Thanks for all d help. ![]()
