Get a different SSD (recommend Samsung 850 evo)
for ram I would get either a single 8 GB stick and upgrade later or get a 2x8GB pack.
That monitors also about the size of a notebook.. I'd at least get something 24". - But thats more so personal preference.
https://linustechtips.com/topic/657245-pc-build-help-pl0x/#findComment-8499334
Replace the SSD and the HDD with a SanDisk Ultra II 480 GB.
Also, change the cooler and PSU to a reputable brand. (EVGA for PSU and Corsair and NZXT for cooler)
i5-8600K -  Asus Strix Z370E - Asus GTX 1060 Strix - EVGA 650W P2 - Samsung 970 Pro 500GB - G.Skill TridentZ 16GB
https://linustechtips.com/topic/657245-pc-build-help-pl0x/#findComment-8499405
If you don't really need the optical drive, this build will come in under budget. If has a larger ssd and the desired 16GB of memory. As well as a better monitor.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($227.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.99 @ Newegg)
Motherboard: Asus Z170I PRO GAMING Mini ITX LGA1151 Motherboard  ($159.99 @ SuperBiiz)
Memory: G.Skill NT Series 16GB (2 x 8GB) DDR4-2400 Memory  ($63.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($89.99 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.49 @ OutletPC)
Video Card: EVGA GeForce GTX 1060 6GB GAMING Video Card  ($249.99 @ B&H)
Case: Fractal Design Core 500 Mini ITX Desktop Case  ($49.99 @ NCIX US)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($44.99 @ NCIX US)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($18.88 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($50.00)
Monitor: Acer H236HLbid 23.0" 60Hz Monitor  ($129.99 @ B&H)
Total: $1163.28
Generated by PCPartPicker 2016-09-08 22:40 EDT-0400
https://linustechtips.com/topic/657245-pc-build-help-pl0x/#findComment-8499518
