I got 2 pc at the moment
1 with no videocard and a i7 4790 3.6 GHz
and 1 w an AMD fx 9590 4.7 GHz and 2 R9 290 Tri X 8gb
So i have an idea to buy a new case + motherbord where i can put my i7 in and the 2 videocards
or should i buy a 1080 or a different new videocard ( are 2 x R9 290 tri X better then a 1080? ) with the i7 or amd fx
So the products i have now are
SABERTOOTH 990FX
Amd 9590 4.7 GHZ
i7 4790 3.6 GHZ
850W power sup
16g ram
Enough storage
i dont know what i need to do
keep the amd pc?
buy for 250 euros a new case and motherbord so i can keep the i7 if he is better then the amd
or i can keep the case evry option is open but i dont know whats the best
https://linustechtips.com/topic/656203-help/
The i7 will destroy the 9590.
https://linustechtips.com/topic/656203-help/#findComment-8478650
2 minutes ago, Letharas said:
So the GHz doest mean shit
so is it wurf to buy a new motherbord?
Amd vs intel the GHz doesnt mean anything.
https://linustechtips.com/topic/656203-help/#findComment-8478699
