Im looking at a new monitor setup for my rig and i wanted an Ultra wide 21/9 but i have been told now by a few people that its not supported by allot of games and it can cause latency problems ect. is this a real thing? if so i will go triple monitor setup but i hate the bezels.
https://linustechtips.com/topic/655736-ultra-wide-problems/
If the games have problems of incompatibility with ultrawide, they also have them with triple monitors. The latency problems depend on the monitor model, it has nothing to do with it being ultrawide, as far as I know.
DESKTOP PC - CPU-Z VALIDi5 4690K @ 4.70 GHz | 47 X 100.2 MHz | ASUS Z97 Pro Gamer | Enermax Liqmax II 240mm | EVGA GTX 1070Ti OC'd
HOME SERVER | HP ProLiant DL380 G7 | 2x Intel Xeon X5650 | 36GB DDR3 RDIMM | 5x 4TB LFF Seagate Constellation 7.2K | Curcial MX500 250GB | Ubuntu Server 20.04
https://linustechtips.com/topic/655736-ultra-wide-problems/#findComment-8464065
Input lag isnt really a reported on the monitor spec sheet, so you need to do some research. A lot of games dont support 21:9 natively so it'll usually stretch the 16:9 image across (i've had this issue). For some games, you could modify the ini and force it into native 21:9. On others you cannot.
Windows 10 Edu | Asus ROG Strix X570-F Gaming | Ryzen 9 3950x | 4x 16GB G.Skill Trident Z RGB| ROG Strix GeForce® RTX 2080 SUPER™ Advanced edition | Samsung 980 PRO 500GB + Samsung 970 Evo Plus 2TB + 8TB Seagate Barracuda | EVGA Supernova 650 G2 | Alienware AW3418DW + LG 34uc87c + Dell u3419w | Asus Zephyrus G14
https://linustechtips.com/topic/655736-ultra-wide-problems/#findComment-8464200
And for the ones that you can't, flawless widescreen is a fantastic program. or so I've been told.
(Note it only has support for specific games)
https://linustechtips.com/topic/655736-ultra-wide-problems/#findComment-8464256
Most newer games are supporting 21:9 just fine, minus prerendered cutscenes, those always look like trash regardless of aspect ratio.  For games that don't natively support the aspect ratio, you can look online, there may be a simple solution on wsgf. That's my go-to.  If it can't be done, the game will render in its supported aspect ratio pillarboxed.  I've yet to encounter a game that stretched, maybe because I have my gpu set to preserve original aspect ratio of the content?  Though I believe that's what it does by default.
I've had no complaints since getting my Acer x34. Great monitor. If all else fails it works as a 27" 16:9 monitor, which isn't a bad thing to fallback to.
Thrive on change. Embrace volatility.
https://linustechtips.com/topic/655736-ultra-wide-problems/#findComment-8475277
It depends on how you have your minor set and the game settings. I haven't had issues of games being stretched once I switched the resolution/monitor settings/in game screen ratio.
First build every: Intel Core i7 4790K, Asus Z97-A/USB 3.1 motherboard, Kingston HyperX FURY 1866 2x8 16GB Kit, Gigabyte Windforce GTX 970 G1 Gaming, Corsair Obsidian 450D Black ATX Mid Tower, Samsung 850 EVO 250GB & 3TB Toshiba HDD, EVGA SuperNOVA 750W G2, Corsair H100i GTX 240mm, Gigabyte Bluetooth 4.0/Wifi Card, Logitech G700S. Running on Windows 10
Surface Pro 3: i5 4300U with 8GB of ram and 256GB SSD. Running Windows 10 Pro
https://linustechtips.com/topic/655736-ultra-wide-problems/#findComment-8484327
Last two games I played (MGS PP, Lawbreakers) didn't support them natively and required a hack to display the resolution properly.
https://linustechtips.com/topic/655736-ultra-wide-problems/#findComment-8486279
