Dont get the 360, for just a few dollars more you can get a 460 which is about as fast as the 270x which is faster than the 360. I know its confusing but thats just how it is.
For reference.
Aside from that there's nothing else really wrong with the system though you could spring for a cheaper case and get a better PSU like an EVGA 430w instead of using the one that comes with that case. It would only end up being a bit more expensive and it would give you more options later and be better quality.
"The of and to a in is I that it for you was with on as have but be they"
https://linustechtips.com/topic/655263-budget-entry-level-build/#findComment-8420467
2 minutes ago, kefizh said:
yeah even a highscool teenager could save up for this
for sure. would work much better than my $350 laptop that barely plays well on games with low settings.
I have no idea what to put here so I'll just put what I'm putting here so I guess now I know what I'm putting here.
https://linustechtips.com/topic/655263-budget-entry-level-build/#findComment-8422514
