Help planning a NAS?
Solved by Guest,
I feel you will be unable to see any real benefit over gigabit especially when using slow 5400rpm drives to write too. The build seems a little overkill for only two drives, wouldn't a pre-built solution be cheaper/ a better fit for this few a number of drives?
Either a 2 bay NAS attached to the home network -> http://www.newegg.com/Product/Product.aspx?Item=N82E16822108331&cm_re=nas-_-22-108-331-_-Product
or;
a higher speed USB 3.0 RAID enclosure like this (I personally use this one and it's served me for the last few years well) -> http://www.newegg.com/Product/Product.aspx?Item=N82E16816322012&cm_re=2_bay_raid-_-16-322-012-_-Product
will provide much more value for this number of drives
