Router into switch data speed slow
Solved by ERSCreeper,
2 minutes ago, Silvanor said:Hey everyone,
I found a router somewhere and i thought i would hook it up to my network as a switch.
I have 4 LAN ports and 1 WAN. The WAN i just ignor. My input is a cable from the main router and goes into LAN port 1. Then i have a PC on LAN port 2 and another PC on LAN port 3.
My problem is is that if i take the cable from my main router and plug it into my pc i get 150MBit/s. But if i plug it in as mentioned above i only get 80Mbit/s.
The 2nd router is a cisco N150.
Thanks in advance
Well considering the N150 is only has 10/100 ports. You would need to buy a cheap gigabit switch for faster speeds.
