I have a toshiba 2tb hdd in my system specs below and recently it started spiking to %100 when i go on chrome and forget games or rendering and opening files is slow  i know my harddrive is dying what can i do to get a little more life out of it this dosen't make sense only got this a couple months ago
https://linustechtips.com/topic/653634-storage-issue/
A drive is most likely to fail in the first few months or after years of use.
Run a smart scan and see what's going on. If it's actually dying, then RMA the drive. But there are other issues which can cause drive usage to sit at 100% -- virus, malware, an issue with the OS, etc... So also run a virus and malware scan.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/653634-storage-issue/#findComment-8391027
