I have a 750D with just the stock fans and I plan on upgrading them to better fans in the future but I think if I'm going to invest in some better fans I should at least have better control over them. My motherboard only has 3 fan headers for case fans and the control on the headers is limited. I can't completely stop the fans and I can't change the temperature location on any of the headers they are all stuck on CPU temp. I was wondering if anyone knows of a good programmable fan controller that is maybe a PCI-e card or something...
https://linustechtips.com/topic/653498-better-fan-controller/
The NZXT Sentry 2 or 3 would be good choices.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/653498-better-fan-controller/#findComment-8389616
If you are using motherboard headers, you will unfortunately be limited by them.
Usually, the CPU fan headers will allow you to get the full spectrum of your fans, while the "SYS" headers will act a bit weird, not being able to lower your fans down to the lowest possible.
If you want more control over what fan reacts to what, you should definitely give SpeedFan a try. It's a B to figure out and set up, but once you do it works wonders. It won't be able to get past the motherboard header limitations, though.
If you want absolute control on your fan rpm, you should get a hardware controller that connects directly to your PSU. It can either be DC based or PWM. I'm pretty sure there are some that can connect to a PWM header on your motherboard just to get a reading, but deal with the fans on their own. That coupled with SpeedFan might be what you're looking for.
~ Specs bellow ~
Windows 10 Pro 64-bit [UEFI]
CPU: Intel i7-5820k Haswell-E @ 4.5-4.7Ghz (1.366-1.431V) | CPU COOLER: Corsair H110 280mm AIO w/ 2x Noctua NF-A14 IPPC-2000 IP67 | RAM: G.Skill Ripjaws 4 32Gb (8x4Gb) DDR4 @ 2666mhz CL15 | MOBO: MSI X99S Gaming 7 ATX | GPU: MSI GTX 1080 Gaming (flashed "X") @ 2138-2151Mhz (locked 1.093V) | PSU: Corsair HX850i 850W 80+ Platinum | SSD's: Samsung Pro 950 256Gb & Samsung Evo 850 500Gb | HDD: WD Black Series 6Tb + 3Tb | AUDIO: Realtek ALC1150 HD Audio | CASE: NZXT Phantom 530 | MONITOR: LG 34UC79G 34" 2560x1080p @144hz & BenQ XL2411Z 24" 1080p @144hz | SPEAKERS: Logitech Z-5450 Digital 5.1 Speaker System | HEADSET: Sennheiser GSP 350 | KEYBOARD: Corsair Strafe MX Cherry Red | MOUSE: Razer Deathadder Chroma | UPS: PowerWalker VI 2000 LCD
Mac Pro 2,1 (flashed) OS X 10.11.6 El Capitan 64-bit (NAS, Plex, HTTP Server, Game Servers) [R.I.P]
CPUs: 2x Intel Xeon X5365 @ 3.3Ghz (FSB OC) | RAM: OWC 16Gb (8x2Gb) ECC-FB DDR2 @ 1333mhz | GPU: AMD HD5870 (flashed) | HDDs: WD Black Series 3Tb, 2x WD Black Series 1Tb, WD Blue 2Tb | UPS: Fortron EP1000
https://linustechtips.com/topic/653498-better-fan-controller/#findComment-8389622
