Weird memory management BSOD issues.
29 minutes ago, Remixt said:Two different sets of 2X8gb
That's why your 5930k hates XMP so much. The XMP setting for that memory is certified to run at the specified voltage, speed and timings for the two sticks alone. During the binning of memory sticks, the manufacturer tests a 2 x 8 set as a pair only. You'd think that you can just combine two sets as long as they were same make and model, but that's not how it works.
The quality of the memory increases as the sets grow in quantity or sticks increase in density when it pertains to x99. This is why you'll find DDR4 sets certified for x99 and z170. They may look identical, but they aren't. The set certified for x99 will run on a z170 platform, but not the other way around. Skylake has a much more forgiving memory controller (IMC) and can run just about anything. x99, not so much.
This is not to say that you can't get the memory working on your setup, but you will more than likely never get it to run XMP right out of the box. Every now and then folks get lucky and buy two separate sets and they work together, but all this means is that they were lucky enough to get two very closely matched sets with regards to quality.
Your best bet is to continue the manual adjustment, but there should be no need for you to run 1.5v just to get 3200 out of those sticks. 1.4v to 1.45 should be more than enough to help you offset any quality differences between the set. You may also need to increase your VCCIO just a tad to help the IMC on your CPU deal with the RAM a little better.
It's definitely some trial and error. The key thing is to verify all of the changes you make. AIDA64, specifically the Cache and Memory Benchmark can let you know if your heading in the right direction with your timings as you go. Obviously, you want to check basic stability as you go as well which can also be done with the AIDA64 memory stress test. I wouldn't recommend that as your final stability check, but it's great for spot checking you timings.
Going back to your question. No, your memory isn't necessarily more stable at higher speeds as that's almost never the case. It's just a matter of your memory happens to seem more stable at the higher speed because of the timings that you currently have set. Adjust your timings correctly for 3200 and your memory will certainly be more stable than it is at 3400. I don't know of any HWE chips running 3400 at decent timings stable. There are some BWE chips doing it, but it's not common there either.
**additionally, once you get the correct memory settings and help your CPU's IMC out with some additional VCCIO, you'll more than likely be able to dial that 4.6 overclock that you want. ![]()
