SAPPHIRE NITRO Radeon™ R9 380 4G D5 and i wanna watercool it just for the higher OCs. Is mine capatiable with the kraken g10
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
https://linustechtips.com/topic/652914-aio-cooling-on-gpu/
2 minutes ago, Teddy07 said:
Why dont you just sell the card and use the saved money from water cooling to buy a better card instead?
Would boost performance more...
No i just want higher clocks. I like overclocking a lot. Maybe call me a amature overclocker on a budget.
Build
https://linustechtips.com/topic/652914-aio-cooling-on-gpu/#findComment-8384026
that is weird aproach but it should be, kraken g10 is compatible with almost every card.
but here
https://www.reddit.com/r/Amd/comments/47bz04/nzxt_added_r9_390_390x_380_380x_to_the_kraken_g10/
and
ASUS Maximus VII Hero | i7 4790K OC 4.8GHZ | 4x8GB 2400MHz MSI GTX 1070 alphacool eiswolf gpx pro
Samsung 850 EVO 520GB + Corsair 525gb + 275gb SSD  2TB Seagate Barracuda | 8TB Seagate Archive
Cooler Master HAF-X 942 | EVGA Supernova 1000W 80+ Platinum | Custom watercooling loop (gpu+cpu)
360mm+180mm rad and 10 fans | Swiftech D5 mcp655-B
https://linustechtips.com/topic/652914-aio-cooling-on-gpu/#findComment-8384034
Doubt your card can go much higher with an AIO also you need to get a proper VRM cooling if you go with the G10.
https://linustechtips.com/topic/652914-aio-cooling-on-gpu/#findComment-8384139
Well i was thinking going with artic cooling one. the one which the vrm heatsinks
Build
https://linustechtips.com/topic/652914-aio-cooling-on-gpu/#findComment-8384439
I can completely understand where you are coming from. There is something about overclocking that I love. With that being said, the card you have is not notorious for overclocking well at all. I doubt that you would see much of an increase by using water.
If you do go with water, I would use the Kraken G10 with a Corsair H105 and then just buy copper heatsinks separately for the power delivery.
|| i7-8700k @ 4.9GHz || Asus Z370-i || HyperX Fury 32GB @ 2400MHz || Nvidia Titan Xp || 500GB Samsung 950 Pro || Deepcool Captain 240 RGB white || Phanteks Enthoo Evolv ITX Glass || InWin Aurora fan kit || Corsair RM750x white || Ensourced Customs sleeved extensions || Tesoro Gram Spectrum white || Logitech G603 ||
https://linustechtips.com/topic/652914-aio-cooling-on-gpu/#findComment-8385196
i am stuck with 120mm rad or i will have to mod.
I hate myself for going the 200r route.
Build
https://linustechtips.com/topic/652914-aio-cooling-on-gpu/#findComment-8385305
You will still get decent cooling. Definitely better than air.
https://linustechtips.com/topic/652914-aio-cooling-on-gpu/#findComment-8385485
11 hours ago, Bcat00 said:
It could work but i just dont understand why you would do that when a new card yields better performance with that money.
because overclocking
Build
https://linustechtips.com/topic/652914-aio-cooling-on-gpu/#findComment-8389290
