My Rig:
motherboard: GA-970A-D3 AMD 970 Chipset Socket AM3+
GPU: 1060 SC GTX 6GB
CPU: AMD FX-9590 4.0GHZ
RAM: 16gb DDR3
PSU: 800 Watts
Case Fans: 8
CPU Cooling: Corsair Hydro Series H60 120MM Radiator and 120MM Single Fan    Closed loop
When I play games my fps will drop from the hundreds down to 10-20 fps for about 30 seconds then goes back up. I have tried so many solutions to fix it but nothing helped. Only thing I haven't tried was posting about it. This is my first time ever posting so I am sorry if this isn't the best way to post it or if I haven't put enough information in it. I know for a fact that it is not how I applied the thermal paste , I have applied it according to the pea method.
https://linustechtips.com/topic/652726-urgent-need-help/
Maybe your gpu is throttling. What is the temps when gaming
System
  • CPU
    I7 6700K Overclocked to 4.6 GHz at 1.33v
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
    GSKILL RIPJAWS V DDR4 16GB 3000MHZ
  • GPU
    MSI GTX 1070 GAMING X 8G overclocked to 2063 MHZ and 8900 MHZ memory clock
  • Case
    NZXT S340 RED
  • Storage
    WD 1TB BLUE AND SAMSUNG EVO 250GB SSD
  • PSU
    EVGA 650W GQ
  • Display(s)
    LG 25UM58-P ULTRAWIDE and LG 29UM58-P 29 ULTRAWIDE
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
    LOGITECH G502 PROTEUS SPECTRUM
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/652726-urgent-need-help/#findComment-8382295
