So, basicly I'm limited to 900Eur [$1000] aprox. so I can go a little over, but well ive seen some builds and stuff, this is what I came up with, correct me please, I'm the most worried by not buying SSD, as most people say its really needed... but I came up with this: Click Here [P.S I am not from deutchland, its what I did so I can get it in Eur format...]
Please correct me if I can improve it not going over the 900 too much...
P.S I will not buy a 1070 since my monitor is 59Hz kinda crappy, 24" :P I might be wrong on the crappy but meh..
https://linustechtips.com/topic/652705-needs-a-little-help-p/
Just now, williamb87 said:
http://de.pcpartpicker.com/list/rzQY9W
Now your have an ssd that will hold the os and a couple apps.  Also you don't need a 600w psu for a 300w build so I switched that for a 430w which saves money.
That board is good, but for 10€ more or so you can get the Hyper which should allow him to overclock.
https://linustechtips.com/topic/652705-needs-a-little-help-p/#findComment-8382197
