http://pcpartpicker.com/user/AwesomeElite/saved/77ZxrH I need a psu for this system. for now i plan to run my cpu with a stock fan so recommendations are appreciated for both components. In the future i may switch to what ever is new and around $400 so please make it future proof. Also i will be buying a hhd in the future 120 is not enough even i know that. This is gunna be my first ever build so thank you all SO much for helping pick the psu and cpu fan.
https://linustechtips.com/topic/652137-psu-for-my-system/
Why are you using a locked 4790? The Xeon 1231 will be just as good and cheaper.
Anyways, something at 800W is furtureproof in case you want to SLI.
https://linustechtips.com/topic/652137-psu-for-my-system/#findComment-8376653
Why not Skylake, for one?
https://linustechtips.com/topic/652137-psu-for-my-system/#findComment-8376693
