Have you already bought that case? If not, don't.
If so, your cooler height is 154mm:
http://pcpartpicker.com/products/cpu-cooler/#h=14,154
The Cryorig H7 would be my pick for an air cooler. If the case supports water (doesn't look like it would take a 240 with a GPU installed), then you'd get much better results from that.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
