CPU: i7 6700k or 6700
CPU Cooler: Be Quiet Dark Rock Advanced C1
GPU: EVGA GTX 1080 SC        Bought already
CASE: Be quiet Silent base 600
MOBO: MSI Z170A Krait gaming 3X
RAM: 16GB Corsair Vengance LX DDR4-3000
PSU: Be Quiet 600 Watt Modular 80+ Silver
NZXT Hue +
I have a few questions:
I´m considering to wait to buy the rest of the computer until Kaby lake comes out. Would the i7-7700 be compatible with the motherboard? I read somewhere that it will be compatible however only with a BIOS update, can i update the mobo without a compatible cpu? Also i belive the ram speed isnt supported by the Cpu, will it be supported with kaby lake? Will i have to call windows support if i just reuse the same ssd that i have used previously?
Im buying from www.mindfactory.com and have a budget of around 1550 Euros. It will be used for mostly gaming but also Blender (3D animation/modeling). I have 2 cheap 1080p monitors and am planning to add a 4k panel in the middle to be able to play 1080p with triple monitor by making the 4k one use 1080p and sometimes play on the 4k monitor.
Thanks for any help or comments on the build
https://linustechtips.com/topic/651059-1080-build-plz-help/
KaybLake is rumored to be on the LGA 1151 socket.
Several motherboards out there support BIOS flashing WITHOUT a cpu installed so you could flash to it without having a supported CPU.
RAM. DDR 2133 is officially what is supported by CPU's. But with XMP you can get it to the 3000mhz without issue.
Windows is actually tied to the Motherboard for its "entitlement" with how windows is calling it now. You might be able to call them and get it re-registered, but should be prepared to purchase a new key in the event they will not.
With a Z170 board, you should get a K sku'd CPU so you can overclock in the future even if you have no plans to immediately.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/651059-1080-build-plz-help/#findComment-8365527
Thank you,
do you know if the Motherboard that i plan on using supports the Bios flashing without the cpu?
https://linustechtips.com/topic/651059-1080-build-plz-help/#findComment-8365540
What's your budget without the GTX 1080?
There should be some motherboards out there that don't require the physical CPU to flash the BIOS to support the new CPU. For example, ASUS motherboards can use a USB to BIOS flash without the memory or CPU in place. Kaby Lake is rumoured to be on the same socket so it should work.
2133MHz is simply the JEDEC standard. What you should be concerned whether or not your motherboard can support that fast RAM, not the CPU. In this case, it can.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/651059-1080-build-plz-help/#findComment-8365542
Just now, Graffi said:
Thank you,
Here is the official page from MSI for your motherboard
https://us.msi.com/Motherboard/Z170A-KRAIT-GAMING-3X.html#hero-overview
From a quick look through it doesnt appear to.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/651059-1080-build-plz-help/#findComment-8365545
Budget without the 1080 is  850 Euros, i could reuse my old power supply to have a bit more budget. I may be able to borrow my friends 6700 to flash the bios
https://linustechtips.com/topic/651059-1080-build-plz-help/#findComment-8365553
What's your current power supply?
https://linustechtips.com/topic/651059-1080-build-plz-help/#findComment-8365567
I dont know exactly however its a 80+ gold and has enough power power the 1080.
If i purchase the motherboard after kaby lake was released it will have the Bios for the i7-7700k right?
https://linustechtips.com/topic/651059-1080-build-plz-help/#findComment-8365596
Is there a brand name on it? Efficiency rating and the amount of power it can output doesn't determine whether or not it's a good quality power supply?
https://linustechtips.com/topic/651059-1080-build-plz-help/#findComment-8365656
