Alright guys, I'm new to this website but I've heard everyone is pretty helpful, so here's my question..
With a budget of $900 usd(Texas) what could I build? I can't seem to decide on anything, and when I do it gets way too expensive, I need a gaming rig so i can officially join the pc mustard race.
Any help will be appreciated, thanks.
I'm not including peripherals or monitors in this budget, also I'm not yet ready for a multi monitor setup either so don't worry about those things.
Edit: I forgot to say i'm going to be running windows 10 as well.
https://linustechtips.com/topic/651000-build-help/
Alright, my friend I've come up with a beast mid-sized gaming PC, it will serve you well for years to come & upgrading is going to be easy in this case!
http://pcpartpicker.com/list/7nXhkT
Over the years I've learned to not cheap out on two major parts of a PC the Power supply  & case!
Hopefully this is helpful, send me build pics if you go with this!
https://linustechtips.com/topic/651000-build-help/#findComment-8367815
http://pcpartpicker.com/list/4Tf2m8
not too be ride to the other did but bro you have a k chip cpu and and b150 motherboard which is not OC able
my build is overclockable includes a better gpu 16gb of ram(2400) which is pretty high, I will admit the room on the ssd could be bigger and I am 5$ over sorry
https://linustechtips.com/topic/651000-build-help/#findComment-8368402
Thank you both for the advice, I'm not going to be starting yet though but I have an idea of what to do, I'll probably start ordering everything closer to the end of the year, which gives me time to save of plenty of extra money just in case I decide to go a bit bigger on the budget, but both of those look pretty good, thank you!
I don't know if threads stay open for that long but if they do I'll post pictures on here once I start
https://linustechtips.com/topic/651000-build-help/#findComment-8368508
