I'm looking to buy one of these to replace an E6300 on another computer.
https://www.amazon.com/dp/B000LRMR26/ref=olp_product_details?_encoding=UTF8&me=
https://www.amazon.com/Intel-BX80562Q6600-Q6600-Processor-Retail/dp/B000MM37JW/ref=sr_1_3?ie=UTF8&qid=1472431139&sr=8-3&keywords=q6600
What's the difference between the two and which one do I get?
BTW I'm looking to buy it within an hour, please answer.
https://linustechtips.com/topic/650880-cpu-buying-help/
They are exactly the same. Same item model number = same product.
i7 - 6700k || Asus ROG Strix 1080Ti || Corsair Vengeance LED 32GB 3200Mhz || Corsair 760T White || Corsair HX850 || NZXT Kraken X62 || Asus Z170-A || Logitech Proteus Core 502 wireless || Logitech G915 TKL ||
https://linustechtips.com/topic/650880-cpu-buying-help/#findComment-8363708
