Hi everybody, I've been wanting my own rig for a while now and I've put together a list of components that can be purchased in my residing country(Sri Lanka)
This PC will be primarily for 1080p Gaming and Video Editing and I will upgrade to at-least a 1440p monitor in the near future.
I want this PC to run the latest games for the next 3 years at max settings 1440p
Please advice on my build list and i have attached two of the store price list links if anyone wants give me a better alternative.
http://www.redlinetech.lk/pricelist
https://docs.google.com/spreadsheets/d/1ZMGJc69uk2fVEFPKNu1UboxE3Wh5ftI9yUJuIbQzZi4/pubhtml#
I would love to decrease a couple of 100 dollars if possible.
This is the list,
    NanoTek (LKR) USD
Proccessor Intel® Core™ i7-6700 Processor (8M Cache, up to 4.00 GHz)  Rs.     46,000.00  $        317.40
Motherboard MSI Z170 G43  Rs.     22,500.00  $        155.25
VGA Palit Geforce GTX 1070 Dual 8GB GDDR5  Rs.     78,000.00  $        538.20
HDD Western Digital Blue 1TB WD10EZEX (2Y)  Rs.       8,500.00  $          58.65
RAM G.SKILL RIPJAWS4 16GB KIT DDR4 2400Mhz  Rs.     13,500.00  $          93.15
Case COOLER MASTER CM Storm Scout 2  Rs.     13,000.00  $          89.70
PSU Corsair VS Series™ VS650 650W 85% efficiency (3Y)  Rs.     12,500.00  $          86.25
Cooling Cooler Master Hyper 212X air cooler  Rs.       6,000.00  $          41.40
Fans Cooler Master JetFlo 120mm Red x 4  Rs.       8,000.00  $          55.20
DVD Rom ASUS DVDRW 24X BULK (1Y)  Rs.       2,750.00  $          18.98
Monitor AOC 22" IPS LED I2279VWHE FRAMELESS 1080P (HDMI+VGA) (3Y)  Rs.     21,500.00  $        148.35
     Rs.      210,750.00  $     1,454.18
Thanks in advance!!
Cheers!
https://linustechtips.com/topic/650403-first-gaming-build/
Would recommend upgrading to a 1080 if your looking for 1440p maxed out for the next 3+ years, the 1070 may need some tweaking of settings. Also, you should get an SSD for boot drive. Once you go SSD you will NEVER.... EEEEEEEEEVVVVVVVVVVVEEEEEEEEEEERRRRRRRRRRRRRRRR.... be the same again... Also, from personal experience the Cooler Master JetFlo fans.. they literally sound like a jet engine... I would highly recommend NOT getting those and get something from Corsair like the Airflow 120mm Quiet Editions.
Oh, and welcome to LTT!!!
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/650403-first-gaming-build/#findComment-8359307
Recently used JetFlo and they really do sound like jet engines xD
"The only way to do great work, is do do what you love." -Steve Jobs
https://linustechtips.com/topic/650403-first-gaming-build/#findComment-8359311
This is the list,
    NanoTek (LKR) USD
Thanks in advance!!
Cheers!
Keep the HDD and add this SSD - https://pcpartpicker.com/product/3kL7YJ/samsung-internal-hard-drive-mz75e250bam
Also remove the CM Fans and add a couple of these - https://pcpartpicker.com/product/yYkD4D/corsair-case-fan-co9050009ww
https://linustechtips.com/topic/650403-first-gaming-build/#findComment-8359321
9 minutes ago, FlushaDev said:
do the 120mm fans, not 140mm.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/650403-first-gaming-build/#findComment-8359350
Not the corsair vs, not good. Especially for a rig like this. What other choices do you have?
https://linustechtips.com/topic/650403-first-gaming-build/#findComment-8359362
Thanks legacy99, I don't think I could go for a 1080 at this juncture cause it's just too expensive, however thanks for the fan tip, is 4 fans overkill though?
https://linustechtips.com/topic/650403-first-gaming-build/#findComment-8359711
These are my options, what do you think I should go for?
Cooler Master JetFlo 120mm Blue2000In Stock
Cooler Master JetFlo 120mm White2000In Stock
Cooler Master JetFlo 120mm Red2000In Stock
Corsair AF120 QE RED2800Out of Stock
Corsair AF120 QE BLUE2800Out of Stock
Raidmax 120mm LED Fan RED1500Out of Stock
Raidmax 120mm LED Fan BLUE
https://linustechtips.com/topic/650403-first-gaming-build/#findComment-8359716
no, just that the jetflo's are extremely loud, they do legitimately sound like jet engines even with LNA's attached. The Corsair AF120QE's would be ideal.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/650403-first-gaming-build/#findComment-8359750
Community Standards
"Beast Mode"
https://linustechtips.com/topic/650403-first-gaming-build/#findComment-8359753
Palit is exclusive to Europe so I can not comment on them, but I do believe TTL at OC3D does review them so I assume they will be decent and near identical to all the rest of the mainstream cards.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/650403-first-gaming-build/#findComment-8359786
Here is a video of the fans.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/650403-first-gaming-build/#findComment-8359801
