Any version of HDMI will do 1080p@60fps. Its if you go to a higher resolution or want a higher refresh rate that the monitor's HDMI standard would matter.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
1 minute ago, PepsterHD said:
Hi there,
So I recently bought a MSI GTX 1060 and it has a HDMI 2.0 port. If I were to connect my HDMI cable (Which is high-speed) to my monitor will it support atleast 60Hz?
Thanks.
What version of HDMI is on your monitor? What are your monitor specs? (The answer is surely yes it will, but I'm just double checking)
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
PSU Tier List | CoC
