Hello! Whenever I try to run CPU-Z I get the error code 0x5. I looked around for a solution, but I couldn't find anything that could fix my problem. I've already tried installing an older version, but that doesn't help! If anyone has another solution please tell me.
Thanks!
https://linustechtips.com/topic/649510-cpu-z-error-0x5-help/
Thanks!
Try running it as administrator.
Also, use the no-install version, and see if that fixes your problem.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/649510-cpu-z-error-0x5-help/#findComment-8352929
