I think the only thing you can do is call corsair customer support if that even exists.
GPU: ASUS Strix GTX 1070,  CPU: i5-6600k OC to 4.0 GHz,  PSU: Rosewill Capstone G750 750W,  Mobo: MSI Z170A Krait Gaming,  Case: NZXT H440 White,  Memory: G.Skill Ripjaws V 16GB (2x8),  HDD: Seagate Barracuda 2TB, Mouse: Razer Ouroboros,  Keyboard: Razer BlackWidow Chroma, Mousepad: Razer Overwatch KB+M pad, Headset: Corsair Void RGB,  Monitor: 1x ASUS PB277Q 27" 1440p & 1x HP Pavilion 25cw 25-inch 1080p
https://linustechtips.com/topic/648470-corsair-rebate-help/#findComment-8340753
3 hours ago, ShadowTechXTS said:
Can I resubmit it?
I don't think so.  They will probably think you are trying to get your rebate twice.
https://linustechtips.com/topic/648470-corsair-rebate-help/#findComment-8340776
https://corsair.secure.force.com/home/home.jsp
https://linustechtips.com/topic/648470-corsair-rebate-help/#findComment-8340785
