cable mod planning
hay guys so i want to buy these cables but are these all the right cables and are there enough for everything???? heres the link for the cables https://store.cablemod.com/product/cablemod-st-series-modflex-cable-kit-black-red/
PCPartPicker part list: http://pcpartpicker.com/list/p8JxsJ
Price breakdown by merchant: http://pcpartpicker.com/list/p8JxsJ/by_merchant/
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($319.99 @ Newegg)
CPU Cooler: Corsair H100i v2 70.7 CFM Liquid CPU Cooler  ($101.99 @ Newegg)
Thermal Compound: Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste  ($6.88 @ OutletPC)
Motherboard: MSI Z170A GAMING M5 ATX LGA1151 Motherboard  ($172.99 @ SuperBiiz)
Memory: G.Skill Ripjaws V Series 16GB (4 x 4GB) DDR4-2400 Memory  ($74.98 @ OutletPC)
Storage: Samsung 250GB 2.5" Solid State Drive  ($72.99 @ B&H)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($157.90 @ Amazon)
Video Card: Gigabyte GeForce GTX 1080 8GB G1 Gaming Video Card (2-Way SLI)  ($629.99 @ SuperBiiz)
Case: Phanteks Enthoo EVOLV ATX ATX Mid Tower Case  ($164.99 @ Newegg)
Power Supply: Corsair CXM 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($89.89 @ Newegg)
Operating System: Microsoft Windows 8.1 OEM 64-bit  ($84.99 @ NCIX US)
Software: Sony Movie Studio 13 Suite Software  ($104.95 @ Newegg)
Monitor: BenQ GL2460HM 24.0" 60Hz Monitor  ($139.00 @ B&H)
Headphones: Logitech G230  Headset  ($34.99 @ Best Buy)
Other: Rosewill toolkit ($15.00)
Other: 1Headphone holder ($17.00)
Other: Red led strips ($12.00)
Other: Best ever gaming keyboard ever the:  Redragon Karura K502 USB Gaming Keyboard, 7 Switchable Backlight Colors, 104+ Keys    ($24.00)
Total: $2846.51
Generated by PCPartPicker 2016-08-24 16:10 EDT-0400
https://linustechtips.com/topic/648406-cable-mod-planning/
Total: $2846.51
MAn, this is a beefy system! Gl mate. Cable bundle looks good.
https://linustechtips.com/topic/648406-cable-mod-planning/#findComment-8340086
No that cable set won't work with your PSU. The cables you linked to are for Silverstone power supplies and you have a Corsair one. If you stick with Corsair you'll want the "C-Series" cables from CableMod. You will also need to change the PSU as you have a semi modular one in your list and you need a fully modular unit otherwise the 24-pin cable from CableMod will be useless.
duc sequere aut de via decede
CPU: i7 6800K | Mobo: MSI X99 Gaming Pro Carbon | GPU: SLI EVGA 980 Ti Hydro Copper | PSU: EVGA 1000P2 | Memory: 64 DDR4 Corsair Dominator Platinum | Storage: Samsung 950 Pro 512GB M.2 & Samsung 850 Evo 1TB| Case: Be Quiet! Dark Base Pro 900 | Display: Predator X34 & Dell U2715H | Cooling: Custom Loop
Custom hard line watercooled Fractal Node 202 ITX build log
https://linustechtips.com/topic/648406-cable-mod-planning/#findComment-8340148
can you give me a link for it
https://linustechtips.com/topic/648406-cable-mod-planning/#findComment-8340220
Well if you pick a modular PSU first then it's easy to match up the cables.
https://linustechtips.com/topic/648406-cable-mod-planning/#findComment-8340576
