You can partition the drive, but why do you want to set aside from space? If you're doing it for longevity reasons, don't bother. The drive will long outlast your use no matter how you treat it.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/648332-need-help-with-ssd/#findComment-8339320
