Hello Guys,
Help Needed,
As I have no technical experience, I'm in a need of dire help. My PC was acting up  from last week and since yesterday, it won't start.
Here are the video grabs when I try to start it
https://m.youtube.com/watch?v=10zNtJ9FvXA
https://m.youtube.com/watch?v=RxVbUMDJ9R4
https://m.youtube.com/watch?v=n44Wq5nZZLo
System configuration is
Cpu.       Intel i7 4790k
Mobo.   Asus z97 pro
Hdd.      Wd sata 2tb green
Ssd.        Samsung 120GB
PSU.       Corsair RM750
Gfx.       Asus gtx 970 4GB
UPS.     Apc 1100va
Cabinet. Nzxt
RAM    Kingston Hyperx 16Gb
Please help guys, thanks in advance.
Aaditya Singh
https://linustechtips.com/topic/647337-help-needed-pc-is-not-working/
I don't see any RAM on your list, you do have it right ? scratch that, not a new build I see now. Try taking the RAM out and putting it back in.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
18 hours ago, A User said:
What's the RAM you got?
I need to make sure It's compatible with the CPU and mobo.
Thanks dude for taking your time out for this.
Kingston hyperx 16GB. PC was running perfectly fine for the last one year. Never Played any game on it never ran any heavy duty softwares like maya, 3d Max, etc. Only used it for general usage. But, It was acting up since last week and stooped working 2 days back.
@tikker dude.
tried that already, but it is of no use. Any other idea what's causing this.
2 hours ago, Aaditya01 said:
@tikker dude.
Perhaps try with one stick at a time to see if one (or both) is dead.
Pull one stick out, or try get some more. I think It might be some dead RAM you have there.
Or, you can test that RAM In a friends PC to see If It works, It may be your mobos DIMM slots.
Either way, I think It's a RAM problem, personally.
Good luck...
