Maximus VI Formula shutdown issues
Go to solution Solved by Frederik I. Hansen,
Never mind! Just found out Intel RTS was the root of all the evil! :P
Hi! I just built my system, but have an issue with the motherboard (I think). Almost every time I shut it down, I get the error code "05" (Or "OS") on the display on the motherboard. I've checked in the manual, and it says nothing about this error code... There's 03, 04, 06, 07, but no durking 05! It also has a habbit of restarting in stead of shutting down. I could really use some help... Oh, and the CPU I have in it is a 4770K, in case you need to know :)
Thanks in advance
https://linustechtips.com/topic/64534-maximus-vi-formula-shutdown-issues/
