Please help me im desperate.
I have been trying to install windows 7 on this z170-a pro motherboard for about 15 hours but it asks for cd/dvd drivers, I plug my usb 2.0 drive with drivers but it does not recognise any drives in the browser, I tried different iso's, putting the drivers in the windows ISO itslef, disabling sata, usb 3.0 etc. nothing works please help...
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
https://linustechtips.com/topic/645270-please-help-me-im-desperate/
Are you plugging the usb flash drive into a USB 3 port? Windows 7 doesn't support USB 3 without you installing a driver first. Try a USB 2 port.
I edit my posts a lot.
just get a case with a window !/s
What happens if you make a bootable drive with rufus and try to boot from it ?
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
yeah im using a usb 2.0 port for all my devices
Elemental
Laptops
Just now, KuJoe said:
+1 to what @MrDrWho13 said. I ran into this issue also, setting my ports to USB 2.0 in the BIOS fixed it.
I cant find it on the z170-a pro mis motherboard
Elemental
Laptops
Just now, MrDrWho13 said:
So it recognises hard drives but not USB devices?
I dunno, I just know that when I try and install windows 7 and it asks me for drivers it does not detect any USB drives I plug in to install drivers, the only thing that appears is an x drive which is virtual I think
Elemental
Laptops
Hey I keep seeing this issue and I'm sorry but I don't know the solution. There are many threads on here with the same problems so maybe you can find the solution in one of those. Maybe there's a problem with the way you put the installer on the USB drive?
Personally I'd burn a DVD with the installer since that shouldn't have these issues.
I dont have a dvd rom rip
Elemental
Laptops
