2 minutes ago, Thread212 said:
-___- some people just cant watch or click suspicious link.
U can try to describe your problem and put the video in the bottom of the topic.
The link is on the website I used the website to reccord but  with my h100 I v2 I can't find were to plugin in the 2 headers
https://linustechtips.com/topic/644365-need-help/#findComment-8296588
I have a H100i V2 in my system. RTFM. Open your manual, go to page 5, it tells you how to install power right there.
Basically on this unit you plug it in to the CPU header on your motherboard. You then plug your 2 fans into the 2 available connectors coming off the pump header you just plugged in.
https://linustechtips.com/topic/644365-need-help/#findComment-8296619
Ty
https://linustechtips.com/topic/644365-need-help/#findComment-8296654
