So I've got enough money to do one of 2 things whiCheck I want both but can only do 1 at a time. My choices are upgrading my gtx 970 to a 1070 or change my aio which has been making some noise (and I hate any sounds on my pc) to custom water cooling. I need some opinions on this soon thanks.
https://linustechtips.com/topic/644255-upgrade-decision-help/
3 minutes ago, TheKingKobra said:
1080p I play battlefront, ark, rocket league, and soon maybe overwatch
Definatly get a new AIO cooler or custom loop. You can get a second 970 for VR and that will do fine. My brother has 2 970's and has a Vive, his experience of it is very good!
https://linustechtips.com/topic/644255-upgrade-decision-help/#findComment-8295466
Just now, TheKingKobra said:
Good idea what about custom water cooling?
A custom loop is good but difficult. People are going to say its easy but in realilty its not. If you watch Jayz Two Cents or Awsomesauce Hardware they have both got custom loops and both had issues each time. They are very experiance in custom loops. I would suggest a H115i AIO as its much cheaper and keeps my OC'ed i7 6800k under 35degreesC under full load.
https://linustechtips.com/topic/644255-upgrade-decision-help/#findComment-8295482
I really only want something that's basically silent and I might consider water cooling my gpu
https://linustechtips.com/topic/644255-upgrade-decision-help/#findComment-8295501
Water cooling loops are as loud or sometimes louder than a AIO cooling such as the H115i as there is less fans at lower speeds and still keeping temps low.
https://linustechtips.com/topic/644255-upgrade-decision-help/#findComment-8295509
