2expensiv4most
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
https://linustechtips.com/topic/643636-razer-blade-stealth/#findComment-8288971
1 minute ago, JacobKS said:
Can you give me some other choices but it must be an ultrabook to I really need the features of lightweight.
Depends on your budget
https://linustechtips.com/topic/643636-razer-blade-stealth/#findComment-8288980
Dell XPS15?
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/643636-razer-blade-stealth/#findComment-8288982
19 minutes ago, JacobKS said:
What are your thoughts on this one?
Its build quality is poor, the keyboard is shit, it overheats and Razer support is cancer.
https://linustechtips.com/topic/643636-razer-blade-stealth/#findComment-8289003
maximum of $1200?
Dell XPS 13
Lenovo ThinkPad X1 Carbon
Lenovo ThinkPad X250 or X260
Asus UX301
https://linustechtips.com/topic/643636-razer-blade-stealth/#findComment-8289007
maximum of $1200?
I'd go for something like a XPS15
https://linustechtips.com/topic/643636-razer-blade-stealth/#findComment-8289008
Just now, JacobKS said:
I might think about on the XPS 13.
Anything is better than a Razer craptop
https://linustechtips.com/topic/643636-razer-blade-stealth/#findComment-8289047
Sad to hear about Razer is shit everywhere :( I'm quite a Razer fan I have all their chroma peripherals. :) the best Razer product for me is their Mamba TE, I dont like my kraken pro and blackwidow chroma anymore.
https://linustechtips.com/topic/643636-razer-blade-stealth/#findComment-8289077
Well. Their laptops are utter shit. Both the B14 and BS overheat, both have poor build quality and QC issues and Razer support is useless.
https://linustechtips.com/topic/643636-razer-blade-stealth/#findComment-8289111
and is that normal for that price they only have 1yr warranty for all their laptops? and do you recommend the macbook air 12inch?
https://linustechtips.com/topic/643636-razer-blade-stealth/#findComment-8289121
2 year warranty is standard, Anything below that should not be bought. Macbooks are the same crap. Not worth the money
https://linustechtips.com/topic/643636-razer-blade-stealth/#findComment-8289129
I might go on the XPS 13, I just don't like the logo "DELL" :)
Not buying a good laptop cause of the logo is flat out stupid ._.
https://linustechtips.com/topic/643636-razer-blade-stealth/#findComment-8289149
dbrand
Laptop Main
(Retired) Zbook 15: i7-6820HQ, M2000M, 32gb, 512gb SSD + 2tb HDD, 4k Dreamcolor
(Retired) Alienware 15 R3: i7-6820HK, GTX1070, 16gb, 512 SSD + 1tb HDD, 1080p
(Retired) T560: i7-6600U, HD520, 16gb, 512gb SSD, 1620p
(Retired) P650RS: i7-6820HK, 1070, 16gb, 512gb + 1tb HDD, 4k Samsung PLS
(Retired) MBP 2012 Retina: i7-3820QM, GT650M, 16gb, 512gb SSD, 1800p
https://linustechtips.com/topic/643636-razer-blade-stealth/#findComment-8290067
