So i recently got my gtx 970 and a CX 600 watt power supply 80 plus bronze. I am getting max 150 fps in csgo on lowest settings, if i go max it's between 60-110. It feels really low when i look at the numbers, my GPU is at 20-30% load and that load number does'nt move if i max out or choose the lowest settings possible at 1080p. The performance is equal too my latest graphics card before upgrading (r7 240) but that was running at 100% load at all times. Is there any fix for this? i've tried the latest drivers (368.81) and i'm currently using 362.00. Theres no improvement or performance loss if i change drivers. I can max out GTA V getting 30-80 FPS in large cities while not ever having over 50% load, the card itself refuses to go over that limit even if i have set the maximum power usage too the max which is 106. Paired with the gtx 970 i got an amd a10-7800, i get it it's an bottleneck if you now say so but the performance i have is equivelant too my r7 240 which i think is hella surprising. CPU load never goes above 50% either.
Sorry for the wall of text, but i seriously need help!
https://linustechtips.com/topic/643177-having-fps-issues-with-gtx-970/
Go into nvidia control panel and ensure your power is set to maximum performance.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
do you have vsync enabled?
Community Standards
"Beast Mode"
Verify in-game that its off. When I personally turn vysnc on in BF4 my GPU never gets above 40% utilization while maintaining my 60 FPS.
Community Standards
"Beast Mode"
It is off in any game i play, there is times where i dip below 60 and either the proccessor or the gtx 970 does'nt do anything about it in usage wise.
have you tried switching pci-e slots?
CPU: Ryzen 7 5800x3D | MoBo: MSI MAG B550 Tomahawk | RAM: G.Skill F4-3600C15D-16GTZ @3800CL16 | GPU: RTX 2080Ti | PSU: Corsair HX1200 |
Case: Lian Li 011D XL | Storage: Samsung 970 EVO M.2 NVMe 500GB, Crucial MX500 500GB | Soundcard: Soundblaster ZXR | Mouse: Razer Viper Mini | Keyboard: Razer Huntsman TE Monitor: DELL AW2521H @360Hz |
1 hour ago, Sebastian5698 said:
Only got 1 on my current motherboard, so i can't.
i had the same issues, turned out my pci-e slot is damaged. Can you test the GPU in another PC?
CPU bottlenecking
CPU bottlenecking, it might be it but my friend got same proccessor and motherboard but he got an r9 280x and got almost double the fps i do.
What cpu? Are they overclocked? Check msi afterburner and any other software to make sure that there isn't a framerate limiter enabled. (No I'm not talking about vsync and this would bypass any vsync setting in the nv control panel)
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
