So I'm trying to build my PC on 800 $ budget only for gaming and i want to know what do you hardware experts think
of the chosen parts. and any tips or better part suggestions would be appreciated.
note: parts are sometimes expensive in Iran
Jaguar X2 Case 48 $
Green GP450A-UK 450W (I know it's a no name PSU but it's popular in my country) 58 $
ASUS B85 Pro Gamer mobo 105 $
Haswell Core i3-4160 106 $
Apacer Black Panther DDR3 1600 Mhz CL11 36 $
Seagate Barracuda ST2000DM001 2TB 70 $
BenQ GW2270H monitor 140 $
I haven't chosen my GPU yet but here are my options (these are used parts) :
Sapphire R9 290 4GB 228 $
EVGA GTX 970 4GB 285 $
GTX 970 EXOC Black Edition 251 $
MSI GTX 770 2GB 200 $
GTX 960 2GB 185 $
I don't know which is the best choice , plz help. (sry for English)
https://linustechtips.com/topic/642489-first-gaming-build/
Jaguar X2 Case 48 $
GTX 960 2GB 185 $
Go EVGA GTX 970, but apart from that it looks good, ill have another look at the build compatibility later.
I suck a typing, preparw for typos.
Desktop
CPU: Ryzen 7 3700x MOBO: MSI X570-A Pro RAM: 32 GB Corsair DDR4
GPUS: Gigabyte GTX 1660ti OC 6G  CASE: Corsair Carbide 100R STORAGE: Samsung Evo 960 500GB, Crucial P1 M.2 NVME 1TB   PSU: Corsair CX550M CPU COOLER: Corsair H100x
LAPTOP
Apple Macbook Pro 13 M1 Pro
https://linustechtips.com/topic/642489-first-gaming-build/#findComment-8277301
The Galax 970 EXOC is a pretty good 970 variant. It has decent clocks, a nice shroud and backplate. Would recommend it for $30 less.
Btw does this store have an online site you can pick parts from? If you give me a budget USD or local currency I'll try and pick parts out for you.
  • Quote people's post else they won't know you replied.
Crapware | 4670k | Hyper212X | GSkill RipjawsX 16GB | Sapphire R9 280x VaporX | 840EVO 120GB | 1TB BLACK + BLUE
Logitech G102 | Corsair K70 MX Brown | HyperX Cloud
https://linustechtips.com/topic/642489-first-gaming-build/#findComment-8278261
I was thinking the same the 970  EXOC is the best deal here however, the owner says it has no guarantee left . Should i still buy it ?
And this is the link to the site :     http://www.digikala.com/Main/Electronic-Devices/Computer-Parts/
it has no English lang option but you can use translate and it should be fine . Thank you for help.
https://linustechtips.com/topic/642489-first-gaming-build/#findComment-8278519
go gtx 1060. maybe a better opinion
My main rig  Shardsedge
 ☟ INFO & SPECS
  • Information:
This build is made for video editing, Gaming and livestreaming.
probably 65% of this build has been bought used.
  • Specifications:
CPU  AMD Ryzen 7 1700
GPU  Sapphire RX 580 PULSE 4GB
SSD ✦ Toshiba TR200 240GB
HDD ✦ WD Black 160GB 2.5" + WD BLUE 1TB
PSU ✦ Corsair RM750X
RAM ✦ Corsair Vengeance LPX 2x4 (8GB) 3000Mhz
CASE ✦ Corsair Crystal 460X
MOBO MSI X370 SLI Plus
My old pc build  Smoke
 ☟ INFO & SPECS
  • Information:
This build was made for gaming especially, it was my second build.
i had some struggles livestreaming on it because the CPU just wasn't good enough for that.
(I do not have this build anymore)
  • Specifications:
CPU ✦ Intel i5 6500
GPU  Sapphire NITRO+ Radeon RX 470 4G D5
SSD ✦ Kingston SSDNow v300 120GB
HDD ✦ WD Blue 1TB
PSU ✦ Corsair CX450M
RAM ✦ Corsair Vengeance LPX 2x4 (8GB) 2400Mhz
CASE ✦ Sharkoon S25-V
MOBO ✦ MSI H110M ECO
https://linustechtips.com/topic/642489-first-gaming-build/#findComment-8278552
That's a good card but the it hasn't arrived to Iran yet . And I'm guessing it will be around 350 $ here just like the RX 480 which is 330 $ .it's too expensive for my budget and i can't go any higher.
https://linustechtips.com/topic/642489-first-gaming-build/#findComment-8278601
Does the EVGA have warranty in it? If yes go with that one.
Hard for me to browse through the site, chrome is having difficulties translating in Persian.
The list you have looks good except the mobo you got is a bit expensive, get a cheaper H81/B85 mATX board. Use what you saved to get an ssd(Adata SP550 120gb) and 1TB hdd(WD 1TB Blue).
https://linustechtips.com/topic/642489-first-gaming-build/#findComment-8278697
Try substituting these parts to your list and add the overall cost to see if you can fit a Skylake system + SSD/HDD into your budget.
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor
^this doesn't seem to be on stock on that site atm, check for other stores perhaps
Motherboard: Asus H110M-C/CSM Micro ATX LGA1151 Motherboard
Memory: Kingston FURY 8GB (1 x 8GB) DDR4-2400 Memory
Storage: A-Data Premier SP550 120GB 2.5" Solid State Drive
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
https://linustechtips.com/topic/642489-first-gaming-build/#findComment-8278736
What's the budget in Iranian Rial? I'm browsing through digikala to see what's available there :)
Folding@Home ~75k points per day | My Simple Air-cooled Machine Maintenance Guide | Dutch Talk | Building a Wooden Popsicle Stick House
Main rig: i7-3770 stock - ASUS P8Z77-M - 8GB DDR3 1600MHz - 2x Radeon HD6970 2GB - SilverStone GD05-B - Corsair RM650x
https://linustechtips.com/topic/642489-first-gaming-build/#findComment-8278859
This totals about $900 dollars if I'm not mistaken, because 2.8 million toman is 28 million rial, correct? The i3-6100 was not available unfortunately, that would've cut down cost nicely, but the i5 will not disappoint and is an all round great choice. If you can get the GPU from a good source second hand, then that should cut costs and make it around the $800 range, hopefully. The PSU is fine, the brand doesn't ring any bells but the specs are good and it's a gold rated unit. 8GB RAM should be enough to begin with, you can always add 8 more later. This way, you are at least investing in last generation Skylake based CPU and motherboard and DDR4 memory, instead of older Haswell architecture. I hope this helps.
شرح محصول تعداد قیمت واحد قیمت کل
کیس کامپیوتر گرین مدل Oraman - Green Oraman Case
Green Oraman Case
رنگ: مشکی
گارانتی : سرویس ویژه دیجی کالا: 7 روز تضمین تعویض کالا
 1
83,000تومان 83,000تومان
مادربرد ایسوس مدل B150M-A - ASUS B150M-A Motherboard
رنگ: مشکی
گارانتی : 3 سال و 6 ماه گارانتی لایف سرویس
 1 2 3 4 5 6 7 8 9 10
309,000تومان 309,000تومان
پردازنده مرکزی اینتل سری Skylake مدل Core i5-6400 - Intel Skylake Core i5-6400 CPU
رنگ: نقره ای
گارانتی : گارانتی 1 ساله اینوو
 1
608,000تومان 608,000تومان
 1
175,000تومان 175,000تومان
کارت گرافیک ایسوس مدل STRIX-GTX960-DC2OC-2GD5 - ASUS STRIX-GTX960-DC2OC-2GD5 Graphics Card
رنگ: مشکی
 1
835,000تومان 835,000تومان
منبع تغذیه کامپیوتر گرین مدل GP450A-UK - Green GP450A-UK Computer Power Supply
رنگ: مشکی
گارانتی : گارانتی 37 ماه گرین
205,000تومان 205,000تومان
 1 2 3
170,000تومان 170,000تومان
مانیتور ال‌ای‌دی ای او سی مدل E2261FWH - AOC E2261FWH LED Monitor
رنگ: مشکی
گارانتی : گارانتی مادیران
 1 2 3 4 5
415,000تومان 415,000تومان
جمع کل خرید شما :2,800,000 تومان
مبلغ قابل پرداخت :2,800,000 تومان
https://linustechtips.com/topic/642489-first-gaming-build/#findComment-8278981
Green Oraman Case
رنگ: مشکی
 1
رنگ: مشکی
رنگ: نقره ای
 1
 1
رنگ: مشکی
 1
رنگ: مشکی
 1 2 3
رنگ: مشکی
 1 2 3 4 5
That is exactly my budget range :D thanks so much for your help . I can find the i3 6100 in other sites or a store from around my neighbourhood . And about the GPU I'm going with the second hand EXOC GTX 970 that is 880,000 tms which is close to the price of that GTX 960 Strix . Oh and how much fps would the i5 6400 and i3 6100 give me for 1080p gaming ? If they have kind of the same performance rate i might go with the i3  i forgot to mention, there is a 2nd hand GTX 960 Zotac 2gb that is 650 tm , it has left 1 year guarantee .
Edited by Col_DeadEye
https://linustechtips.com/topic/642489-first-gaming-build/#findComment-8279047
In CPU intensive games, like GTA V, you will notice that the i3 will do slightly better than the i5, simply because it runs at a higher clock speed. (3.7GHz vs 3.1GHz) It's hard to say exact numbers matched with the EXOC GTX970, but 50-60 fps with decent settings should be no problem. The video below shows a rough comparison with an overclocked 970. The 970 will be better than the 960 in every way.
https://linustechtips.com/topic/642489-first-gaming-build/#findComment-8279138
