I got a this shitty A4 Tech bloody R8 and I have been using it for almost 3 years with my laptop and it has weird metal feet that started to make scratching noise on my mouse pad, I dont plan on getting a new mouse as this one came free and I only use my laptop once a week when I am back at my place. So I need your suggestions getting this mouse feel like its gliding on my mouse pad for no or almost no cost. I was thinking about removing metal bits and sanding the thing with fine grid that I used while lapping my 3570K.
https://linustechtips.com/topic/641902-worn-mouse-feet-fix/
Glass fabric teflon tape:
http://www.shop.hightechflon.com/ptfe-teflon-tape-selfadhesive/Page-16-2-96-112.aspx
Amazingly frictionless material. It's costly but you only need a tiny piece.
If you can find someplace that'll sell you a small strip you should be set.
https://linustechtips.com/topic/641902-worn-mouse-feet-fix/#findComment-8271742
that looks interesting, ill look around.
https://linustechtips.com/topic/641902-worn-mouse-feet-fix/#findComment-8271756
