C++ program trouble Immediate HELP SOS !!!
Go to solution Solved by OuchMyFaceyHole,
Just now, Runelight said:
what do u mean so how should i do with a single read in variable ??? Im new to C++ thats why
You are asking A or B you only need one variable to do that.
int A = 0;
cout<<"Enter 1 for Blah, 2 for Yay.\n";
cin>>A;
if(A==1){
	cout<<"Blah.\n";
else cout<<"Yay.\n";
OR
cout<<(A==1 ? "Blah.\n" : "Yay.\n");
Hey guys , I got Homework in C++ and got to do it . Please help me from getting punished guys . Immediate help is required . The Problem is ,
Write a C++ program to input a student type A or B . If the student type is A , then initialize the college account with 200$ , otherwise initialise the hostel account with 200$ .
Please guys I need the code for the program,immediately . I hope u will help thanks in advance guys ;)
https://linustechtips.com/topic/641756-c-program-trouble-immediate-help-sos/
That's generally the intention behind homework... you have to do it. Yourself.
No. At least make the effort yourself. Your laziness is not our problem.
The single biggest problem in communication is the illusion that it has taken place.
Well I am like the best programer in class or at least thats what teachers says . But Im having trouble with this one . And cannot , derive an expresion for it . I cannot if else if . That is forbidden by the teacher . Instead I have to do it with conditional operators which are C++ Exclusive . Im having trouble in this one and one more
EDIT : I am also allowed to use the C++ exclusive Logical operators
Edited by Runelight
Welcome to learning. Try it sometime. This is so simple.
Main Gaming PC - i9 10850k @ 5GHz - EVGA XC Ultra 2080ti with Heatkiller 4 - Asrock Z490 Taichi - Corsair H115i - 32GB GSkill Ripjaws V 3600 CL16 OC'd to 3733 - HX850i - Samsung NVME 256GB SSD - Samsung 3.2TB PCIe 8x Enterprise NVMe - Toshiba 3TB 7200RPM HD - Lian Li Air
Proxmox Server - i7 8700k @ 4.5Ghz - 32GB EVGA 3000 CL15 OC'd to 3200 - Asus Strix Z370-E Gaming - Oracle F80 800GB Enterprise SSD, LSI SAS running 3 4TB and 2 6TB (Both Raid Z0), Samsung 840Pro 120GB - Phanteks Enthoo Pro
Super Server - i9 7980Xe @ 4.5GHz - 64GB 3200MHz Cl16 - Asrock X299 Professional - Nvidia Telsa K20 -Sandisk 512GB Enterprise SATA SSD, 128GB Seagate SATA SSD, 1.5TB WD Green (Over 9 years of power on time) - Phanteks Enthoo Pro 2
Laptop - 2019 Macbook Pro 16" - i7 - 16GB - 512GB - 5500M 8GB - Thermal Pads and Graphite Tape modded
Smart Phones - iPhone X - 64GB, AT&T, iOS 13.3 iPhone 6 : 16gb, AT&T, iOS 12 iPhone 4 : 16gb, AT&T Go Phone, iOS 7.1.1 Jailbroken. iPhone 3G : 8gb, AT&T Go Phone, iOS 4.2.1 Jailbroken.
Man I seriously need to get the answer . I tryed every thing known to me . Yet I cant do it . My mother knows programing but only in C and not C++ .So I thought I will get help here . Anyone please help me
The conditional operator (also called ternary operator) is not exclusive to C++, some other languages also have it (just fyi). It's basically just another way to write an if/else statement. Take a look at this tutorial page for them.
23 hours ago, madknight3 said:
The conditional operator (also called ternary operator) is not exclusive to C++. It's basically just another way to write an if/else statement. Take a look at this tutorial page for them.
Man I know what ternary operators are . All I want is the code which i dont seem to understand that particular one
It's just an If else statement with a read in. How are you out of ideas.
But I cant use If else statement u c . If I was allowed I would have done it . But this is new to me and just dont seem to get it
Then use a ternary as someone else said.
How about you post the code you've tried and we can point out what you're doing wrong.
Well man I need to write the code and Im not getting that code .
But how should I use it ???
could u please list the formula code and what type the variables used are
You are being way to lazy. We aren't just going to give you the answer.
please man I need it and if i know the code , i would have written . please man please help me . I have  formula in mind . But I dont understand how to use that.
https://en.wikipedia.org/wiki/%3F:#C.2B.2B
On 8/11/2016 at 9:46 PM, Hunter259 said:
I dont understand whats written in wikipedia . Well the code I have is
char A , B ;
int college , hostel ;
cout <<"Enter student type A or B" ;
(A:B) ? college==200 : hostel==200 ;
is this correct ??? please reply
char A , B ;
First : Why do you have two read in variables when you only need one?
Second : You aren't setting those variables equal to anything. You are just checking if they are equal to 200.
Third : Did you read that page?
(argc > 1 ? a : b) = 1;
Your variable, your operator, your A answer. Then the turinary, if greater than the requirement for A set A = 1, else set B = 1.
Copied from the wiki page:
Quote
condition ? value_if_true : value_if_false
Desktop: Intel i9-10850K (R9 3900X died 😢 )| MSI Z490 Tomahawk | RTX 2080 (borrowed from work) - MSI GTX 1080 | 64GB 3600MHz CL16 memory | Corsair H100i (NF-F12 fans) | Samsung 970 EVO 512GB | Intel 665p 2TB | Samsung 830 256GB| 3TB HDD | Corsair 450D | Corsair RM550x | MG279Q
Laptop: Surface Pro 7 (i5, 16GB RAM, 256GB SSD)
Console: PlayStation 4 Pro
well that I know if conition is true the first expression will evaluate otherwise the 2nd will evaluate . but I dont clearly understand how to use it . Im using c++  for the first time this year
int A = 0;
cin>>A;
if(A==1){
	cout<<"Blah.\n";
OR
What about this one  ,
char type ;
cin>>type ;
(type==A)? college=200 : hostel=200
Tada. You learned.
int A = 0;
cin>>A;
if(A==1){
	cout<<"Blah.\n";
OR
dude i cannot use if else if statements ok
Omg. Why do you think there is a giant OR.
