Hey guys, I'm new here, so bear with me a little.
I tried undervolting my rig for the first time ever.
I have been an enthusiast for almost 20 years and building my own rigs doing all that time too.
Haven't really seen a real reason for me to undervolt before, and honestly it's just for fun now also.
BUT......
As soon as I touch the Voltage Offset in my BIOS, I start having problems doing computer shutdown.
When ever I shut down or restart my rig, it's powering off before it's done shutting down, and as a result also tells me that there is a problem in the BIOS and that it wanna reset (or let me play with it myself)
It happens already at the first step (-0,05v)
What REALLY bothers me about it, is that it seems like it's only a problem doing shutdown... I've run a RealBench stresstest for 1 hour (know it's not long) at -0,20v offset and everything seemed fine... could maybe go lower, but since my rig started acting stupid with shutdowns I started adjusting it the other way again, with the result that I apparently can't touch the volt offset at all :'(
Hope some of you guys here has some advise or experience to help me :)
My rig is:
Intel i7-6700k
Gigabyte Z170X Gaming 7
Swiftech H320-X2 CPU Cooling
Kingston HyperX Fury 2666mhz
Sapphire HD7970 Vapor-X
Corsair AX860 PSU
https://linustechtips.com/topic/641716-undervolting-problems/
BUT......
My rig is:
Intel i7-6700k
Corsair AX860 PSU
Reset CMOS?
https://linustechtips.com/topic/641716-undervolting-problems/#findComment-8269652
you really think it would make a difference?
It's doing as it should when voltage is set to normal...
Edit: would have felt stupid if that was the case... even though I would have deserved it for not trying :/
Didn't help... still shutdown issues as soon as offset voltage is changed
Edit 2: Hmmmm.... seems it's a thing thats wrong with the BIOS.
Decided to give Intel Xtreme Tuning Utility a go (again), and I've made an offset of a little above 0,05v, and it shuts down as it should... don't know how the Intel Utility works, if it's only working inside Windows... but if that's what makes the difference I don't really care :)
Don't have more time to tinker with it right now... but will keep it at the -0,05 offset for now, and play with it some more when I get some more time on my hand.
https://linustechtips.com/topic/641716-undervolting-problems/#findComment-8272005
