I just build my new pc
Spec:- processor core i5 6600
           Ram:- G.Skill Ripjaws 8GB DDR4 3200bus speed
           Mobo:- MSI Z170M mortar
           Psu :- thermaltake 500watt bronze 80
the problem start from yesterday when i try to on my pc it doesn't start ....my ups is on but my cpu doesn't take any power only my mobo led light show on....monitor doesn't display any thing .. after trying couple of time my pc start ... but take many time then previous ..... what should i do plz help ? :'(
https://linustechtips.com/topic/641519-pc-problem/
Make sure that the CPU is sat in properly and that the CPU power cable is connected, make sire the 24 pin is sat properly. Connect a motherboard speaker to see if you are getting any beep codes, it should be in the manual, try taking it off a UPS see if that helps.Did you install the stand-offs?
Have you tried turning it off and on again?
https://linustechtips.com/topic/641519-pc-problem/#findComment-8273665
