So i've been using a 1080p 32 inch TV as my main display for quite some time now although I am planning an upgrade to a 4k or even a 5k monitor but as to what to do with the 32 inch TV I had an idea to mount it using a VESA mount to the wall at the left of my workstaiton and configure it to run as multiclient essentially 4 different virtual displays each with a resolution of 960X540 now the reason I dont wan't to use windows 10's corner snapping feature is because upon each pc start up I will have to move all the programs back to the corners while with it running as 4 different virtual displays windows should remember that the programs are located on the virtual displays another thing that I will note is that I am using HDMI to connect this and my graphics card only has 1 HDMI connector for the TV. if anyone has any info on softare tricks or can tell me if this is possible or not any information is apprecianted
Thanks in advance ~LazyChaz
PC:
CPU: Ryzen 9 3900X @ 4.25GHz
RAM: 32GB Patriot Viper Steel 15-15-15-36 @ 3600MHz
Motherboard: Gigabyte Aorus Master X570
GPU: Powercolor RX 6800XT Liquid Devil
SSD: 500GB 970 Evo Plus, 500GB Pioneer NVMe, 480GB BX500 SATA.
PSU: Corsair AX1600i
Cooling: EKWB Watercooling
Case: O11 Dynamic XL + EKWB Reflection distro plate
Laptop: Framework Batch 10
I5-1135G7
24GB 2400MHz
500GB PM951
https://linustechtips.com/topic/640136-a-project-ive-been-planning/
