So, I finally found a full time job, after getting out of the military a few years ago, and now have steady income to put toward a gaming build. I plan on re-using my GTX 750 that I currently have, but for the most part, this is going to be a complete system from scratch. I tried to keep it under $800 so I can get it sooner, but I wanted it to be as good I could. I'm also taking suggestions for any improvements that anyone has.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($198.99 @ SuperBiiz)
Motherboard: ASRock B150 Gaming K4 ATX LGA1151 Motherboard  ($79.99 @ Newegg)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  ($76.99 @ Newegg)
Storage: Sandisk Z400s 256GB 2.5" Solid State Drive  ($64.99 @ Newegg)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($67.99 @ SuperBiiz)
Case: Corsair Air 540 ATX Mid Tower Case  ($129.99 @ Newegg)
Power Supply: Corsair RMx 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($88.89 @ OutletPC)
Total: $787.82
Generated by PCPartPicker 2016-08-08 15:39 EDT-0400
Edited by krevan88
Updated Initial Post to have the most recent build
"All the subtlety and nuance of a napalm enema."
- The Joker
Batman: Arkham Knight
https://linustechtips.com/topic/640023-how-does-my-plan-look/
I see nothing that will cause fires, explodes or make your life terrible so it gets a go from me! :)
PC Build Guide – Intel i3 ATX: (Less than 700$)
*CPU: Intel Core i3-6100 (does not need after market cooler)
*GPU: Gigabyte Radeon RX 480 8GB (can be replaced by RX 470, GTX 970 or R9 390)
*Mobo: ASUS H170-PLUS D3 ATX LGA1151 Motherboard
*RAM: Hyper X Fury 16GB (2x8GB) DDR3-1866MHz (most be 1.35v or less)
*PSU: XFX TS 650W
*Storage: Seagate 2TB 3.5" 7200RPM SSHD
*http://pcpartpicker.com/list/3vhDxY
PC Build Guide – AMD FX ATX: (Less than 800$)
*CPU: AMD FX-8370 + Wraith Cooler (does not need after market cooler)
*GPU: Gigabyte Radeon RX 480 8GB (can be replaced by R9 390, GTX 1060 or R9 Fury)
*Mobo: MSI 970 Gaming ATX AM3+ Motherboard
*RAM: G.Skill Trident X Series 16GB (2x8GB) DDR3-2133MHz
*PSU: XFX TS 650W
*http://pcpartpicker.com/list/vMDCLD
PC Build Guide – Intel i5 ATX: (Less than 900$)
*CPU: Intel Core i5-6600K + Cooler Master Hyper 212 Evo
*GPU: Gigabyte Radeon RX 480 8GB (can be replaced by GTX 1060, R9 Fury or GTX 1070)
*Mobo: ASUS Z170-PLUS D3 ATX LGA1151 Motherboard
*PSU: XFX TS 650W
http://pcpartpicker.com/list/9zsb8K
Some budget builds I made, you may see better or cheaper parts? ;)
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
https://linustechtips.com/topic/640023-how-does-my-plan-look/#findComment-8252740
The high-end i5 is overkill for the GTX 750, but if you plan on upgrading to a 1060 or something down the line then that build looks great!
My PC: MSI X99s SLI PLUS///Intel i7 5820k///Corsair H100i///Crucial DDR4 12GB///EVGA Supernova Gold 750w G2///ASUS GTX 1080 Strix///Phanteks Enthoo Luxe///Intel 730 240GB SSD///WD Blue 1TB///Intel 6250 WiFi
Current Peripherals: Sennheiser HD598///Corsair K70 LUX///Logitech MX Master///Razer Destructor 2///Saitek X52///Acer X34 Predator
https://linustechtips.com/topic/640023-how-does-my-plan-look/#findComment-8252752
That or RX 480! :P
https://linustechtips.com/topic/640023-how-does-my-plan-look/#findComment-8252777
Motherboard: Gigabyte GA-H170-GAMING 3 ATX LGA1151 Motherboard  ($99.68 @ OutletPC)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.00 @ Amazon)
Power Supply: Thermaltake 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($54.99 @ Newegg)
Total: $773.52
Generated by PCPartPicker 2016-08-08 11:25 EDT-0400
You can cut the psu down to a 550W. The H170 board only supports CF so unless you plan on running 2 x AMD GPU's then 750W is overkill. Something like the EVGA G2/GS or Corsair RMx would be good.
https://linustechtips.com/topic/640023-how-does-my-plan-look/#findComment-8252884
Okay. I'll check it out. I only went with that one because I was unsure. Thank you.  I'm unsure on what video cards are decent for Crossfire support. I really only know anything about Nvidia cards. Any suggestions for when I upgrade if I do want to CF?
- The Joker
https://linustechtips.com/topic/640023-how-does-my-plan-look/#findComment-8253157
It's 90% of the time better overall to just buy a more powerful card and sell the old one than it is to deal with SLI or CF. There have been a few edge cases (on the Nvidia side for example at the launch of the 900 series a lot of people bought 2x 970s instead of a 980 and for $100 more got better performance), but even so CF and SLI definitely have their issues.
And I forgot about the RX 480! Seems like a great card for the price.
Also, I agree about upgrading the tier of a power supply. 650w max, look at the EVGA Supernova series or as someone mentioned Corsair RM series. Make sure it's modular unit, you'll thank me later when it comes time to do cable management- there's a lot of wires in a computer, so don't add any unnecessary stuff.
https://linustechtips.com/topic/640023-how-does-my-plan-look/#findComment-8253513
Okay, So I changed out the power supply for this one, and as far as CF/SLI, if I just do a single card, and stay with Nvidia, would that supply work for something up to a 1060 or should I just keep the other one for when I go to actually upgrade?
- The Joker
https://linustechtips.com/topic/640023-how-does-my-plan-look/#findComment-8253605
A 650W power supply will be more than enough for a 1060 (or even a 1070 or 1080). An RX 480 will run on the same supply as well- but I'm not sure about crossfire (but again, CF/SLI shouldn't be your goal/first option unless you absolutely need more power than a single card can provide).
https://linustechtips.com/topic/640023-how-does-my-plan-look/#findComment-8253641
