Nas Trouble
Solved by MrSheep110,
On 8/13/2016 at 9:39 PM, gamerking said:when you want to wipe the flash drive have fun =) its a pain unless you know the disk part commands
I HAVE FIGURED IT OUT!!! It was not the Usbs or the FreeNAS its self BUT the ISO to USB installer that i used "ISO to USB." That installer did not make it a bootable device. AFTER using something else I was able to Boot and install a fresh ISO of freeNAS. The Iso to usb i now use is Rufus. IT works amazing. Thank you for all the help. In the end it was my stupidity that made it work and made me not check my ISO to USB.
