So I have 700€ (maybe 1000€ depend on if I sell my current build)
This is the current build:
i3 540 @ 3.9ghz (could go up to 4.3 but im on stock cooler and it goes to 90c)
8gb RAM
120GB v300 SSD (Got it cus it was cheap)
GTX 660 OC  and my own 120mhz oc. Runs at 35 - 60c
Pretty nice Looking talius drakko case with my some LED strips I added
P7H55m - lx Mobo
Nox apex 600w semi - Modular PSU (had it for a year on several build and has good reviews here in spain)
So New build
PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($238.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.38 @ OutletPC)
Motherboard: MSI Z170-A PRO ATX LGA1151 Motherboard  ($113.88 @ OutletPC)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory  ($39.89 @ OutletPC)
Total: $417.14
Generated by PCPartPicker 2016-08-04 17:27 EDT-0400
I have 2 options, Keep the current PC and use its case, GPU and SSD  or sell it for 300$ (I have another PSU) and buy a new case, GPU and storage
For the Case I was thinking an S340 and for storage a 1tb HDD and a 120gb SSD and for GPU maybe a 1060, 970 or a used 980ti, Really the cheapest possible that can run triple 1080p setup since I have 2 1080p monitors and want to go triple.
This is all a very tight budget, what should I do?
also The cpu cooler is not necesary and is just ther for testing since I have a costum loop arriving.
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
https://linustechtips.com/topic/638094-need-ideas/
bump
Elemental
Laptops
https://linustechtips.com/topic/638094-need-ideas/#findComment-8231946
Unless you plan to overclock, not much need for K CPU, save yourself some money from mobo and CPU and get a decent GPU.
PCPartPicker part list: http://pcpartpicker.com/list/9J4cqk
Price breakdown by merchant: http://pcpartpicker.com/list/9J4cqk/by_merchant/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($198.99 @ SuperBiiz)
Motherboard: ASRock H170 Pro4 ATX LGA1151 Motherboard  ($89.99 @ Newegg)
Video Card: PowerColor Radeon RX 480 4GB Video Card  ($199.00)
Total: $527.87
Generated by PCPartPicker 2016-08-04 19:25 EDT-0400
https://linustechtips.com/topic/638094-need-ideas/#findComment-8232371
