hi all i have a bit of a problem im new to the forum and im trying to build my first gaming rig i currently have a
gigabyte F2A68HM-H motherboard
AMD Athlon x4 854 cpu
8gb of ddr3 ram
700w alpine psu
asus hd7770 2gb gpu
and my problem is when i breadboard my setup it runs with nothing on screen ither through onboard vga,hdmi or pci gpu i dont understand it i know my gpu is working because its been running on my old system for a few months without a problem thanks in advance
https://linustechtips.com/topic/637482-new-build-problems/
Reseat all components, make sure everything is where it should be, give it another go. If that doesn't work, take the GPU out, switch a RAM module around or try with 1 stick of RAM and see what happens.
Folding@Home ~75k points per day | My Simple Air-cooled Machine Maintenance Guide | Dutch Talk | Building a Wooden Popsicle Stick House
Main rig: i7-3770 stock - ASUS P8Z77-M - 8GB DDR3 1600MHz - 2x Radeon HD6970 2GB - SilverStone GD05-B - Corsair RM650x
https://linustechtips.com/topic/637482-new-build-problems/#findComment-8225474
15 minutes ago, techguy2016 said:
tried that m8 still nothing
Did you try the other stick of ram?  Just asking because I was having the same problem with my computer, where everything would run but there would be no POST.  I tried one stick and each slot and then forgot about it, but after hours of trying different psu's, adapters, onboard graphics, monitors, and video cards I finally tried the other stick of ram and viola, i got my picture back and my faulty stick is on the way back to crucial now. Once i pulled my video card completely I saw the RAM debug led lit.
https://linustechtips.com/topic/637482-new-build-problems/#findComment-8225598
2 minutes ago, techguy2016 said:
just tried that @ace_cheaply thanks for ur input but still no joy
Damn, well it was just a thought.  Do you have a speaker hooked up to the mobo for beep codes? not back panel speakers, but case speaker?  The beep codes are here
https://linustechtips.com/topic/637482-new-build-problems/#findComment-8225640
