http://ca.pcpartpicker.com/list/82LmgL
This is my build so far, i have all of this plus a predator x34 monitor right now sitting in my office.
Here's what i believe i am missing...
Gpus i was looking to sli some gtx 1080s, but i am looking at msi x and Asus aftermarkets cards. I would appreciate help on choosing what card to pick.
I would also like a link to a place where i could purchase red sleeves cables to fit my psu and needs. Never had to buy cables and i don't feel like ordering multiple times because i am missing cables. Lol i hate waiting on stuff instead the mail.
I was told for gaming that my motherboard also had good quality sound so a sound card would actually be useless.
I plan on playing multiple games like battlefield 1 or very demanding games at Max resolution with my x34 predator screen.
Waiting for a few replies and will order everything tonight.
Thx.
https://linustechtips.com/topic/637405-help-me-complete-my-build/
Thx.
whoa dude what do you do for a living?
1 hour ago, wrathoftheturkey said:
Dude... I want your job. Why not get Titan Xs while you're at it?
Was told they get extremely warm and i don't want to get aftermarkets cooling solutions added by my stupid self...  And my job is not for everyone trust me lol
Get some ASUS STRIX 1080s. I don't think you will need sli at this point at that resolution unless you are playing extremely intense games like witcher 3 with mods and setting tweaks, buy its up to you. The STRIX ones have some nice RGB and triple fan so good cooling too..
Well I guess Titans without watercooling isnt really the most efficient way it's probably
better to stick to 1080s then. Asus Strix and Zotac AMP Extreme are possible GPUs.
Just a question do you need 2 1TB SSDs? I think it's fine going with one 500GB SSD
for Windows and programs that are supposed to work fast and then get a SSHD for
games and stuff like that. You would safe a lot imo but it's up to you anyway.
I've had two of them already so i will be using them in a raid setup. But if i had to buy a storage solution i would of gone M.2 slot 500gb pcie. But since it's two drives that i already had i am just going to raid zero them most likely.
All the water-cooled 1080s are out of stock, you might want to wait for one of those if you REALLY want to complete the OVERLY OVERKILL KILLER feel.
EDIT: for the price, though, you could probably hire Linus himself to come install a waterblock for you.
Lol i like doing thing's myself and learning from trying, i really want to go sli and i don't know where i would put to water-cooled aio 1080s.
Looking at the Asus strix and the msi gaming x or z as we speak.
Dude... don't use Raid 0, you're using bloody Evos. Use RAID 1, especially if it's for work.
It's going to be a gaming oriented PC So only games and YouTube really.
I have a full on workstation with 3 predator x34 that i use for work. But i will go with a raid 1 solution sounds good.
