best CHEAP Cable Extensions  was looking at silverstone tek.   case is White NZXT S340 Inside case is black   parts are  RED/BLACK            so all  WHITE cables, RED/BLACK cables,    WHITE/RED/BLACK cables cant decide on the colors   i feel like i shld get WHITE so there will be white in the case.
https://linustechtips.com/topic/636825-cable-extensions/
1 hour ago, Snyderracing said:
snip
Silverstone makes good ones. Get whatever color you like most man.
CPU: i7 6700k (4.7 GHz) | GPU: EVGA GTX 1070 FTW (OC) | Motherboard: ASUS Sabertooth Z170 S | Cooling: Corsair H110i GTX | Storage: 250GB Samsung 850 EVO M.2 + 1TB WD Black | RAM: 16GB (2x8) Corsair Vengeance LED (White) 3000MHz | Case: Phanteks Enthoo Evolv ATX | PSU: Corsair RM850i | WiFi Card: TPLink Archer T9E | Case Fans: Noctua iPPC-2000 PWM (3x 120mm in), 2x Noctua NF-A14 PWM 140mm (radiator, painted black), Fractal Venturi HP-14 (1x 140mm out)  | OS: Windows 10 Home 64-bit
https://linustechtips.com/topic/636825-cable-extensions/#findComment-8218193
we offer a wide range of extensions and extension kits featuring combs - http://www.performance-pcs.com/catalogsearch/advanced/result/?name=extension&sku=&news_from_date[from]=&news_from_date[to]=&brand[]=2157&psu_style=&keyboard_style=
https://linustechtips.com/topic/636825-cable-extensions/#findComment-8228442
On 8/4/2016 at 5:03 AM, CableMod said:
$10 to ship  4 cables rlly i cld ship them for $5  usps
https://linustechtips.com/topic/636825-cable-extensions/#findComment-8237179
