Problem with my python program
Go to solution Solved by fizzlesticks,
When referring to member variables inside of a class you have to use self.
So when printing the lights you'll need to change it to self.redlight, self.yellowlight, self.greenlight
Hi guys,
so I am very new to object oriented programming, or any programming in that matter and I have not figured it out quite yet, can you tell me whats wrong here?
class TrafficLight:
    def __init__(self, redlight, yellowlight, greenlight):
        self.redlight = redlight
        self.yellowlight = yellowlight
        self.greenlight = greenlight
    def show_status(self):
        print("Redlight: ", str(redlight))
        print("Yellowlight: ", str(yellowlight))
        print("Greenlight: ", str(greenlight))
tlight_0 = TrafficLight(0, 0, 1)
tlight_0.show_status()
So as you can see I want the traffic light to print its status regarding each light, but as it seems the function "show_status" cannot see the values I set in __init__, how do I make it so it can see them?
	line 9, in show_status
NameError: name 'redlight' is not defined
I am sure its pretty easy, sorry if its cringing you out!
EDIT: Python 3.5
https://linustechtips.com/topic/636371-problem-with-my-python-program/
