first time built
Solved by MrDrWho13,
1 minute ago, deathfinder said:
Exactly
here is a picture of it
It's not the best looking by any means, but it will work. If you find your CPU getting hot, you might want to look into getting a larger cooler. To install the new GPU, you'll need to take the pre-installed one out.
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4
play_circle_filled
Latest From ShortCircuit:
