My first PC build
Solved by Ophidio,
Do not go AMD. That chip is 4 years old now and honestly shouldn't even be on the market anymore. Go with an Intel i5 4460, 6400, or 6500 instead. Even if you are trying to go budget there are much better Intel options that are more budget friendly. Also if you do decide to go AMD do not get a 970 chipset on an FX 8 core. Worst decision you could ever make right there. Kingston SSD Now's are terrible options for SSD's as well. Sandisk SSD Plus is a much better option for the same price or cheaper.
