Part 1:  Hey guys, I'm trying to connect one monitor to two 16 port-kvm switches at the same time. Is it possible? Are kvm switches the best way to go? The computers I'm hooking up only have about 2-4GB Ram so I figured I wouldn't use software to do the connection job.
Part 2: Also, what kind of Ethernet Switch setup should I think about? If I'm running 32 computers taht hook up to the internet what kind of router should I buy? How fast should my modem be?
Thanks for your time and consideration. :)
(I'll understand if you can't answer the Part 2 of the question seeing as how its not under this forum's topic.)
https://linustechtips.com/topic/635809-connect-multiple-kvm-switches/
