Hey my name is samuel. I have recently built my first pc and i was wondering what you people think of it :)
SPECS
CPU - i5 6600
PSU - Corsair HX1000i
MOBO - Asus z170-ar
RAM - 16gb Corsair LED
STORAGE - 2tb Seagate Barracuda
                    240gb HyperX SSD
CPU COOLER - Corsair H80i v.2
CASE - Corsair Spec Alpha
GPU - GTX 1070 (soon to be)
https://linustechtips.com/topic/635738-my-first-pc-build/
SPECS
CPU - i5 6600
MOBO - Asus z170-ar
                    240gb HyperX SSD
The 6500 might bottleneck the 1070 a bit
https://linustechtips.com/topic/635738-my-first-pc-build/#findComment-8205856
Why not a K series processor? Honestly instead of SLI plans, I would of just got 6700k and a good AIO 1070, like an EVGA Hybrid or something. You'd have a nice silent system and a faster one at that.
7800x3d - RTX 4090 FE - 64GB-6000C30 - 2x2TB 990 Pro - 4K 144HZ
PCPP: https://uk.pcpartpicker.com/list/mdRcqR
https://linustechtips.com/topic/635738-my-first-pc-build/#findComment-8205871
Just out of curiosity how long do you think skylake will be the newest gen processor?
https://linustechtips.com/topic/635738-my-first-pc-build/#findComment-8205883
Probably at least a year, I expect new CPUs to launch early 2017. Even then though, resale value will be great plus judging by Intel's latest efforts with Broadwell-E it won't be much of an upgrade. (see 4790k vs 6700k). It will however still be on the z170 socket so you can easily sell your CPU and upgrade when the time comes. But for now, 6700k is what I would go for.
When are you expecting to SLI? If it's like next month, might as well wait a month and get a 1080 instead, you won't have to deal with many issues that way. I personally only SLI if I have the top card, otherwise I feel like I am not making out the most of my money compared to the negatives that come with SLI.
Hope this helps
https://linustechtips.com/topic/635738-my-first-pc-build/#findComment-8205899
two years or so. but why even care if there isnt that much of a benefit (you are still fine running 2nd Gen if OCd unless you really need the newer features)
https://linustechtips.com/topic/635738-my-first-pc-build/#findComment-8205900
Hope this helps
Do power supplies ever go "outdated" / how often should you buy a new power supply??
https://linustechtips.com/topic/635738-my-first-pc-build/#findComment-8205926
I had a Corsair AX1200i for my first build, it was totally overkill for 1 GPU but I had it for 4 years and haven't had a single problem. It came with like 10 year warranty I think as well, or something close to that.
So in short, not really. All they do is provide power so as long as you have a good unit it shouldn't cause you any problems in the next 4-5 years at least.
For your kind of system 1000W is fine if not a bit overkill but it's always nice to have extra hearoom. That Corsair unit you have chosen is fine :)
https://linustechtips.com/topic/635738-my-first-pc-build/#findComment-8205936
